Touch screen monitors compatible with 7600 series NVRs
mariusap
Postby mariusap » Thu Jan 19, 2017 12:43 pm
Could you please recommend a touch screen monitor compatible with 7600 series NVR (NVR HIKVISION DS-7608NI-E2/8P/A)?
I want to keep my NVR in the technical room and connect it via HDMI+USB to a touchscreen monitor which will be near to the door.
I already tried a Dell monitor (S2240T) which was not working, but I understood there are some monitors which are compatible.
thank you
bazuk07
Re: Touch screen monitors compatible with 7600 series NVRs
Postby bazuk07 » Thu Feb 09, 2017 11:55 am
Did you ever get a solution for this?
mariusap
Postby mariusap » Fri Feb 24, 2017 2:06 pm
I could not find a solution yet unfortunately.
Irockzz4
Postby Irockzz4 » Tue Sep 12, 2017 1:31 am
Try any of the HID 2.1 compatible touchscreens. Like . Intellitouch 2500 controllers by ELO commonly uaed for point a sales systems
Tyco makes ELO TOUCHSCREENS. Commercial grade water resistant
Topspec
Re: Touch screen monitors compatible with 7700 series NVRs
Postby Topspec » Mon Jan 15, 2018 3:18 pm
Hi has any got a touch screen to work on this NVR yet if so what screen did you use?
Cheers
