Lan question
Maeth
Lan question
Postby Maeth » Wed Apr 26, 2017 5:54 pm
Hello there, new to the forum and looking for a solution on the next problem:
The situation:
I have to install 2 nvrs with 26 cameras using 2 switchs and the client only gives me 2 ips on his lan... yeah..
So... let say he gives me 192.168.0.99 and 100. Is there a way to set the cameras on 192.167.0.10 to 36 and the nvrs on 192.167.0.1 and 2, and connect to/from the switch on 192.168.0.99 and 100 and make everything work and be happy with pink unicorns at each side smiling at me?
I have no clue about what to do. I tried with nvr and cameras on same range and they work, but i wont be able to get into the nvr from a switch. I tried the switch and nvr on same range but i wont have any signal from the cameras since there is a problem with the ip and also i would be using 2 more ips than what i have from the net.
Any clue??
