Where do I get PCNVR?
ingeborgdot
Postby ingeborgdot » Thu May 18, 2017 3:04 am
Can anyone tell me where I can get the PCNVR download to put on my pc. I would like to try it and see how it works. Thanks.
ingeborgdot
Re: Where do I get PCNVR?
Postby ingeborgdot » Fri May 19, 2017 2:11 am
In the iVMS 4200 main view, there are flashing green boxes that keep moving around and it is very irritating to me. Can I disable them? I don't know what I did to turn this on. How do I turn it off? Thanks.
JHSSecurity
Postby JHSSecurity » Mon Jun 19, 2017 12:28 pm
Those boxes are to identify movement that triggers your recordings under Motion or Smart Events. They can be turned off within the Camera Configuration under "Local". There is a setting there called "Rules" and by selecting "Disable" that should shut off the green boxes. If that does not work, go to the motion detection settings under "Basic Events" and uncheck "Enable Dynamic Analysis for Motion"
