Multiple NVRs
mikroman
Multiple NVRs
Postby mikroman » Tue May 30, 2017 3:59 pm
I have recently fit an 8 channel nvr but then decided I need 9/10 cameras. I have a spare 4 channel nvr are there any reasons why I should not install both nvrs rather than a 16 channel?
Thanks
Re: Multiple NVRs
Postby adam » Wed May 31, 2017 8:40 pm
None other than wanting to be able to view them on the same screen directly from one recorder. Otherwise using apps you can view cameras from more than one device at the same time.
JHSSecurity
Re: Multiple NVRs
Postby JHSSecurity » Mon Jun 19, 2017 3:00 am
Does the spare NVR facilitate the potential recording quality of the 9th camera? You may want to get a new NVR that accommodates the latest camera MP improvements. The New NVR's are now capable of recording up to 12Mp cameras where the old one may only facilitate 6Mp. Although those are examples, you may have a difference between your two NVR's that you may not like if you upgrade.
