H265+ on NVR
rickwookie
H265+ on NVR
Postby rickwookie » Sun Sep 03, 2017 8:15 pm
What's the status of H265+ recording on K and I series NVRs? All the new EasyIP 3 cameras support it, but when I check the datasheets for the NVRs, none of them list it. The odd thing is, if I look at the details of the NVRs on the US Hikvision site the DO list H265+ support.
Is it just a case of waiting for the firmware to be updated to add support, and if so which NVRs will support it and when?
Re: H265+ on NVR
Postby Maxim » Tue Sep 05, 2017 4:19 pm
Similar here in Australia.
I can only speak for the 7700 I series. Whilst I am waiting on replies from a couple avenues about upgrading my firmware which according to Hikvisions local website there is no update and yet the www.hikvision.com/en has two more recent versions.
My Firmware is Ver 3.3.9 Build 160612. (12th June 2016?)
On my NVR software there is a checkbox labelled "Enable H265 (For initial access)".
In the (softcopy) manual that came with the NVR it speaks only of H.265.
So in Australia, the data sheet, the NVR manual and the NVR software only speak of H.265, no mention of H.265+
As to when it is coming I can only guess or hope (this year?)
rickwookie
Re: H265+ on NVR
Postby rickwookie » Wed Sep 06, 2017 10:51 am
Only on the North American site can I find reference to support for H265+...
http://www.hikvision.com/us/Products_1_ ... 32623.html
We have V3.4.95 here in the UK. I can't imagine anything pre 2017 would have support for H265+.
Re: H265+ on NVR
Postby Maxim » Sun Sep 10, 2017 11:37 am
Yes, Unfortunately on the Hik site here in Australia there is no more recent firmware than the version I have. (Support?? what's that).
I have been tempted to use one of the later versions from the U.K. site but they warn about being region specific so I don't want to "Brick" my NVR.
I just looked on http://www.hikvision.co.uk and see that version V3.4.95 you spoke of, that means there are three more recent versions of firmware than what I have.
I would have been better off buying a U.K. system and getting support from the same.
bloupbloup
Re: H265+ on NVR
Postby bloupbloup » Mon Nov 06, 2017 11:13 am
Hi, I have a DS-7604NI-K1 / 4P here in France with firmware V3.4.93 build 170408
I also have a 8MP H265+ Hikvision camera.
I have the option to switch on H265+, however when I switch the H265+ when the resolution size is at its maximum (3840*2160), I lose the video feed of the camera. I have to lower the resolution to make it work. However, it is not interesting for me as it reduce the camera's field of view. I switch off H265+ and come back to H265 to get the camera working at its maximum resolution.
Do you think it is my NVR that bugs when I switch to H265+ in (3840*2160)?
Below you can see the screenshot with the H265+ option. The file size calculation below isn't the one of H265+ but this is the one from a camera in H265 mode. So, i am under the impression that H265+ isn't fully supported yet.
Re: H265+ on NVR
Postby Maxim » Wed Nov 08, 2017 2:31 am
Rickwookie,
About a month ago I updated the firmware on my 7700N1-I4 to V3.4.92 Build 170228 and this still does not have H.265 or H.265+(only H.264+)
Bloupbloup:
I have seen a couple more recent versions of Firmware for however I am not sure if they are specific to your region.
Also what Firmware version is your camera using? Is it current?
What model camera are you referring to? there is Version 5.5.0 170725 Firmware available for some cameras. I looked in the release notes and there were a lot of camera models in the Supported product list.
Users browsing this forum: manuelacu18 and 2 guests
