Renaming my different DVRs for viewing on iVMS-4500
Laidbackguyhk
Postby Laidbackguyhk » Sun Sep 17, 2017 9:24 am
Hi All.
I'm in the process of installing 4 DVRs in different locations, but all for the same people.
They are small guesthouses. I was just wondering if it's possible to give each DVR a "sensible name" i.e. Hotel on South St etc.
At the moment all I get on the phone under the HK -Connect is the serial number of the DVR.
It's not a big deal if it's not possible, but it would make life a bit easier to be able to see what camera group to go too.
Many thanks
Tim
Re: Renaming my different DVRs for viewing on iVMS-4500
Postby Maxim » Fri Sep 22, 2017 7:48 pm
Tim,
You should be able to rename it to what ever you like, I just did it on mine and it works fine, I am on Android and I assume yours is IOS and the screens are slightly different. On your screen shot tap the icon in the top LH corner, That should bring you to your "Device List", Select the device you want to Edit, then select it again, You should now see a pencil in the top RH corner, press this and you will be able to Edit the name. When finished, click the icon in the top RH corner to save your settings.
Michael
