HIK Connect - Device verification code
neilrlsmith
Postby neilrlsmith » Wed Sep 20, 2017 4:05 pm
Hi - I am being asked for this when I add the camera on the app or on the desktop software. Research shows me that it's on the camera (it's not) or under Platform Access on the UI (it's not). I do have the opportunity to bring up Generate a QR code - will that do it? If if it does, how do I scan a bar code on my phone using my phone :D
Thanks for any help.
Re: HIK Connect - Device verification code
Postby Maxim » Fri Sep 22, 2017 5:32 pm
That would be the verification code on the sticker on the side of your NVR/DVR along with its serial number.
Or if you go to the software on your NVR/DVR and go to "System Maintenance/System Info" you should see your verification code there.
Or it should also be at "Configuration/Network/Platform access" on the NVR/DVR UI.
I think I read somewhere that sometimes when you setup an account with Hik-Connect that you may have to create one. I've never had to do it so I can't be sure.
