Videoplayback on Hik Connect apps & other apps not working. Iphone 6
PleaseHelp
Postby PleaseHelp » Sat Dec 09, 2017 3:50 pm
Is anyone else having a problem with the playback feature on the apps on ipad or iphones's?
For the last 6/7 weeks Ive been unable to scroll through the times on video playback on my cameras on the apps?
It will show the live feed fine.
But it wont let me go back in time to watch a recording...It will show it only at 12pm of day but wont let me scroll. It keeps kicking back to 12pm.
If I click on the time & select a specific time it will go to that time but when i go to scroll it wont scroll, it will just go back to the time chosen or to the 12pm time at default at the start. Its really annoying as i cannot simply scroll anymore...
This used to always work fine. I have updated my apps & im using an iphone 6.
At my house i can check playback on my monitor but on my ipads, iphone etc etc it wont work anymore.
PLEASE HELP
fleshinachair
Re: Videoplayback on Hik Connect apps & other apps not working. Iphone 6
Postby fleshinachair » Sun Dec 10, 2017 11:42 am
Hi there,
Just to add, I also have the same issue, remote playback rarely works as it's showing that there are no record files when I scroll back through the timeline from my Android phone, despite my device continuously recording 24/7.
If I access via my PC browser, I can playback all hours of previous days, via the app almost nothing.
They need to fix this $hit. I'm tempted to send my NVR back and get a refund if they cannot sort out such basic issues.
PleaseHelp
Postby PleaseHelp » Thu Jan 04, 2018 4:48 pm
Still no update on this?
The HIK CONNECT app the playback has not worked for nearly 3 months now????
Who do you contact about this?
Such an inept service they provide.
KateRed
Postby KateRed » Sun Jan 14, 2018 2:56 pm
I am also having the same issue - using iPhone 8 Plus
Bcs123
Postby Bcs123 » Fri Feb 09, 2018 12:51 am
[hi Ian having the same problem as any one found out how to sort it ? [/b]
PLEASE HELP
PleaseHelp
Postby PleaseHelp » Fri Feb 09, 2018 7:30 am
I have found out how to fix the video playback scrolling issue.
Since their update you have to for some bizarre reason have your device (smart phone or tablets) in 24 hour time & not 12 hour (am or pm)
So change that in your settings & it will fix it.
It also brings back all the old recorded files.
PleaseHelp
Postby PleaseHelp » Fri Feb 09, 2018 7:32 am
I have found out how to fix the playback scrolling issue.
