Ptz
Elettrovox
Ptz
Postby Elettrovox » Sun Dec 10, 2017 11:37 pm
hello guys I have a nvr 7608 ni -i2 the customer has run all telecamre hikivion except a speed dome of the dahua where many proce I managed through the flow rstp to show it in the nvr, with onfiv should not be done all the possible tests, I can not have the ptz controls of the camera on the nvr someone can help me thanks
Elettrovox
Re: Ptz
Postby Elettrovox » Sun Dec 10, 2017 11:38 pm
Model 5943
Boss
Re: Ptz
Postby Boss » Tue Dec 12, 2017 12:33 am
Have you checked to see what PTZ Protocol that model PTZ uses, common protocols are Pelco-D and Pelco-P make sure you select the correct protocol in the NVR's PTZ settings.
Elettrovox
Re: Ptz
Postby Elettrovox » Tue Dec 12, 2017 10:37 am
Hi in the list of the NVR there are all protocols I tried to acquire the camera directly via onvif and it does not work so I did a protocol costum on the camera management port es: 554 or 37777 I capture the images but not the PTZ and this the problem
Elettrovox
Re: Ptz
Postby Elettrovox » Tue Dec 12, 2017 11:06 am
The Dauha protocol on NVR Hikivion does not exist you have to create the protocol
