Switching from Blue Iris to Hik NVR system....many questions
n6vmo
Postby n6vmo » Fri Dec 22, 2017 5:03 pm
I have been running a 5 camera system with Blue Iris for about 4 years now, but want to decrease some power consumption by using a Hikvision DS-7608NI-I2/8P NVR.
BI system consists of 5 cameras (Hik, Dahua, Swann), a PC, Cisco POE switch with 4 attached cameras and a TrendNet POE switch with a single attached camera for the garage. All components are on the same subnet (192.168.0.xxx).
Therefore, I now have many questions. Here is one of these questions.
How can I attach the remote garage camera to the NVR via the TrendNet switch without a direct cable run to the NVR POE ports?
Basically, I want to replace the BI PC (192.168.0.15) with the Hik NVR without recabling or re IP'ing cameras, if possible. See my attached network configuration.
N6VMO Network Rev 1.jpg (117.05 KiB) Viewed 990 times
Thanks,
John
