Condensation in the lense
Newbie1977
Postby Newbie1977 » Sat Jan 27, 2018 11:46 am
Hi am new to all this however I have just purchased and installed 3 x Hikvision DS-2CD2355FWD-I/GREY 5MP 2.8mm Lens IP67 30 Metre IR Turret. All 3 went up the same in similar positions and all worked fine but then 1 within an hour changed. I have attached pics of one cam working fine and the one which isn’t. Can anyone help tell me what is the issue could be?
Looking at the lense it would appear there’s condensation behind the lense.
Thanks in advance
