Camera status problems
mickf
Postby mickf » Thu Feb 01, 2018 12:11 pm
Hi just joined a few days ago,I said I'd probably be back soon and here I am!
System is Hikvision NVR-104-A/4P 8 channel recorder(just one rj45 port on recorder).3 Hiwatch IPC-B140 4mp poe cameras into a 4 port POE switch.Have activated the devices using SADP and all have an ip address using DHCP.All are shown as active through SADP and in the NVR camera menu.All 3 cameras are marked as "weak password",is it too late to change it if this is the cause of the most important problem which is in the status column all have a red exclamation mark in a yellow triangle?Consequently there is no live view.If I unplug a camera from the switch and plug it back in the status column shows "connected" briefly then goes back to the warning triangle.
Any assistance would be greatly appreciated.
Mick
mickf
Re: Camera status problems
Postby mickf » Thu Feb 01, 2018 1:15 pm
Sorted it now.
Mick
