Repairs to a DVR Motherboard ??
adie2u
Postby adie2u » Wed Nov 16, 2016 2:35 pm
Hi there I have a DS-7308HI-S Dvr 8 way recorder
it just starts up and says Embedded NET Dvr then goes no signal , then repeats the cycle
will not go any futher
I think it may have gotton a spike on the mains as it hasnt got a Surge protector on it
Any ideas on how of if i can fix it ?????
The internal board is a DS-8093 rev1.0
Any help would be appricated
Thanks Adie
Re: Repairs to a DVR Motherboard ??
Postby adam » Mon Nov 21, 2016 1:56 pm
Really not sure on this one, I would say due to the low cost of a new one it will be uneconomical to pay for a repair.
Looking at it you have a very old analogue recorder. These new entry level units will record your analogue cameras at the higher D1 resolution and support new HD Turbo cameras at the same time: http://www.cctvkits.co.uk/hikvision-ds- ... clone.html
You could use your existing hard drive also.
