IVMS 4500 horirble images
jehahn
Postby jehahn » Thu Jan 26, 2017 4:19 pm
I have a windows phone with windows 10 (lumia 640 xl) and I installed the IVMS 4500 to access the images of a dvr DS-7204HGHI-F1, but the live images look horrible and distorted (see attached image). The recordings do not. Anyone have any tips on what could be going on ?! Detail: I'm using mainstream streaming.
WhatsApp Image 2017-01-26 at 09.42.33.jpeg (117.09 KiB) Viewed 796 times
WhatsApp Image 2017-01-26 at 09.40.24.jpeg (82.83 KiB) Viewed 796 times
Re: IVMS 4500 horirble images
Postby adam » Sat Jan 28, 2017 12:49 pm
Can you test this on an android or iphone?
27901591
Postby 27901591 » Thu Apr 06, 2017 10:33 am
If anyone is still experiencing this.....
When you firstly setup IVMS 4500 or similar the image is set to Fluent, which means it reduces the quality of the picture but shows the video without any lagging, if your upload speed is good at the dvr premises then you can set it to "Clear" which will clear up the video, however if your speed is slow it will start to lag as your pulling through a lot more quality video, the icon looks like the one at the bottom left of the attached image usually a rectangle with diagonal lines.
Installer at:IseeU CCTV
Mobile: 07903322632
Web: www.iseeucctv.co.uk
Email: Info@iseeucctv.co.uk
