DS-7200 HD Turbo slowing down internet?
homedigital
Postby homedigital » Sun Sep 17, 2017 4:15 pm
Using virgin media 200mbs cat6 to loft with cheap 10/100 8 way switch in loft. Dvr connected to switch in loft. Internet/ wifi using speedtest is around 150 - 208mbs. As soon as dvr is connected speed drops lo low 100's then after time gets progressively worse until even down to 0.9mbs. It then over time will fluctuate giving done times 50 mbs at best. As soon as dvr is unplugged from switch speeds go back to normal. Internet/ wifi speed been stable for last 4 hours with dvr disconnected. I'm thinking the problem is the switch so I will go and buy a better one tomorrow (gigabyte too). Anyone any experience of this or any experience of dvr connected directly to router causing same issues? Cheers.
