Hikvision ds-7208huhi-k2 DVR. Does it support audio over coax (aoc)
Post Reply
equalizr
Post by equalizr »
I have a new Hikvision ds-7208huhi-k2 DVR. Can anybody tell me for sure if this unit does audio over coax (aoc)? if I have a camera that supports audio(internal microphone) . Hikvision tech support says no it does not support (aoc), yet other people tell me it does on channel 1 & 2. I don’t have a camera as of now that supports audio but could buy one to check & then return it. Is anybody using this unit with (aoc). Thanks for your help
Chris CCTVKits
Re: Hikvision ds-7208huhi-k2 DVR. Does it support audio over coax (aoc)
Post by Chris CCTVKits »
The DS-7208HUHI-K2P does not support audio over coax only power over coax
Post Reply
