Advice Please
Jay Gee
Advice Please
Postby Jay Gee » Fri Apr 14, 2017 4:24 pm
Hello
I would like to purchase a WiFi Hikvision system, with two external cameras and two internal cameras.
One external camera is to be mounted on the corner of my garage, taking the electrical source, through the block wall, and used to survey the area in from of my double garage door.
The second camera would be mounted in an open porch, adjacent to the front door.
The third and fourth cameras would be mounted in the kitchen and hallway respectively.
I have the facility to install a hard drive recorder in an understairs cupboard which currently houses my internet router.
Any recommendations for my proposed system please?
Re: Advice Please
Postby adam » Thu Apr 20, 2017 10:09 am
Hi There,
In terms of wireless you are fairly limited but camera 5 in this IP system does have wifi built in if going for the IWS model:
http://www.cctvkits.co.uk/hikvision-3mp ... ilder.html
Otherwise you could use any of the other cameras with home plugs as a wireless bridge:
http://www.cctvkits.co.uk/solwise-pl-50 ... v-poe.html (one for each camera)
http://www.cctvkits.co.uk/solwise-pl-hl ... rough.html (one back at the recorder)
jimmyscotts
Re: Advice Please
Postby jimmyscotts » Tue Jul 04, 2017 4:17 pm
I you have enough money I advice you to buy the new product line up of WiFi Hikvision system.
alarm monitoring system
