NEED HELP PLZ
wesam_az
NEED HELP PLZ
Postby wesam_az » Sun Apr 30, 2017 10:40 am
I bought new hikvision speed dome camera , Model : DS-2AE5223TI-A, I already connected power supply and TVI port, the camera start moving when I connect the power supply, BUT NO VIDEO ON THE DVR NOR THE HD-TVI TESTER
my question is : do I need to configure the switches (SW1 & SW2), or it's Ok to start everything by default.
thanks in advance
waiting your reply
Re: NEED HELP PLZ
Postby adam » Tue May 16, 2017 8:31 am
Did you get it working, the image should be plug and play?
