Remote app stopped working
Shumz
Postby Shumz » Sun Aug 14, 2016 11:45 pm
Hi there I'm in need of some help.
My remote app has stopped working. It just won't load
Re: Remote app stopped working
Postby adam » Tue Aug 16, 2016 11:51 am
Hi There, have you changed your router at all?
First thing to check is whether your ports 80, 8000 and 554 are still open:
http://www.yougetsignal.com/tools/open-ports/
Danny
Postby Danny » Tue Dec 27, 2016 8:59 am
Since this morning I am confronted with the following problem:
2 Hikvision cameras in the same network: 2CD2042WD-I and 2CD2442FWD-IW
both all the same parameters
using the webbrowser page below "Live view" --> no problem
When I'm using Hik-connect or IVMS 4500 (smartphone) the 2442 is working like a charm, but with the 2042 Hik-Connect says the camera is offline, so I don't see live images. Alarm messages are coming in (with picture).
http://www.yougetsignal.com/tools/open-ports/ says ports 80, 554 and 8000 are open,
also below "NAT" (via browser) --> every port has the status "correct".
Since the 2442 is working I don't think it's a problem with my router...
To be sure it isn't my network I swapped the cameras location but without succes.
I had this same problem earlier and it was solved with disabling the "image encryption" in Hik-connect.
Postby adam » Wed Jan 11, 2017 10:17 pm
Are you accessign these cameras directly or via an NVR?
lindseynicole010
Postby lindseynicole010 » Mon Feb 13, 2017 8:33 am
thanks
