ivms 4500 not working on some routers
aaron kearney
Postby aaron kearney » Wed Oct 12, 2016 7:34 pm
hi, has anyone had the problem where the live feed" times out" when trying to use the APP on a BTHub. if I switch off wifi on my device and use 3/4g , the app works well . Also , I am not on the same network as the NVR, this is remote access, so it's not loop back . The app works ok on the building next doors wifi (plusnet). It looks like the problem is with the BT hub.........are there settings I can change ?!?!
thanks
AK
Re: ivms 4500 not working on some routers
Postby adam » Wed Oct 19, 2016 11:06 am
Very strange if not on the same network and it works elsewhere and on 3g. We have setup many BT hubs without issue although they can be a pain. Unless there is a block on outgoing connections?
jimmyscotts
Postby jimmyscotts » Tue Jun 20, 2017 9:05 am
Why is it not working?
