Connect to NVR Settings via Hik Connect?
ADCAB
Postby ADCAB » Fri Dec 08, 2017 7:43 pm
Is it possible to connect to the NVR Settings via Hik Connect?
The NVR is online, but I need to check some settings in the NVR.
Boss
Re: Connect to NVR Settings via Hik Connect?
Postby Boss » Tue Dec 12, 2017 12:44 am
Yes it is. Depending on what phone you have go to the settings of your NVR, for me on Android a just slide my finger across the connection and select the setup cog then go to device information and select remote configuration.
