Long range IR and camera
Including important information as to why you should only buy from an authorized Hikvision reseller
hainesjbh
Postby hainesjbh » Sun Sep 03, 2017 1:13 pm
Hi all, new here, I would welcome some advice.
I have a IR lap and camera system to monitor wildlife at night from my vehicle.(Not poaching).
I have 180 metre range IR LED flood lamp, which is mounted on a roof bar of my vehicle.
On the dash is a device known as Nightmax viewer which is IR sensitive, the image in viewed on a dash mount LCD monitor.
This device can only see a rather small beam from the IR light.
I also have a Image intensifier hand held device, this can the full range of the IR lamp.
I would like some advice as to which camera and lens would compliment the 180 meter IR lamp.
