DS-7716NI-E4
tomndaka
DS-7716NI-E4
Postby tomndaka » Fri Mar 03, 2017 11:10 am
I have two 8-port hikvision NVR located in 2 separate buildings each with a monitor, and I have two DS-7716NI-E4 NVR.
how do I inter connect them so that I achieve one screen with all 16 cameras?
Just tell me what to connect with what, I will greatly appreciate your support.
Re: DS-7716NI-E4
Postby adam » Sun Mar 05, 2017 10:05 am
The simplest way would be to use iVMS on a PC/Mac, it's meant for the job.
Otherwise, could you clarify how many cameras you have on each of the 4 NVRs?
Ad
