To enable audio recording on a Hikvision NVR/DVR using GUI 4 through the web interface, follow the steps below:
Step 1: Enable Video & Audio in Stream Settings
- Log into the recorder via the web interface.
- Navigate to:
Configuration → Video/Audio - Under Stream Type, select Main Stream (Normal).
- Locate Video Type and change the dropdown to:
Video & Audio - Click Save.
- Repeat the same process for:
- Main Stream (Event)
- Sub Stream
- Click Save after configuring each stream type.
Step 2: Enable Audio in Recording Schedule
- In the left-hand menu, go to:
Storage → Storage Schedule - Click on Advanced.
- Tick the checkbox for:
Record Audio - Click Save.
Step 3: Apply to Additional Channels
Repeat the above steps for each camera channel that requires audio recording.Important Notes
- Ensure the connected camera supports audio.
- Confirm that a microphone is properly connected (built-in or external).
- Verify audio encoding settings if audio is still not recording.
